Tried Uploading a Tune to my PC at work. Used standard serial cable and appropriate power adapter. Set to COM 1, baurate of 57600. No communication. Tried COM 2 setup, same thing. Any ideas?
Thanks!~
PC COM Problem
PC COM Problem
99' Silverado 5.3L 4X4
- 4" Cold Air Intake
- Throttle Body Spacer
- 180 Powerstat
- Predator Programmed 93 (Modified)
- Clear Corners
- 17" GMC 6-Spoke Rims
- Alpine and MTX System
- 180 Powerstat
- Clear Corners
Actually should be using 99-02 PC interface, not E40...
Oh yeah, well let me correct myself, I am using the correct interface as I threw the one I used at home on a disk and brought it to work with me.
- 180 Powerstat
- Clear Corners
- 180 Powerstat
- Clear Corners
OK, if it is not a straight through type serial cable, it will not work.
Also, you should be able to see what com port it is on in the device manager.
Baud rate should be set to 57600.
If you continue to have issues, i would suggest a USB to serial cable.
