I just inherited a 2014 RAM 1500 R/T Regular Cab 5.7 Hemi (51,580miles) mint condition with a PROCHARGER Supercharger Model D1SC & it came with a Diablo i2 tuner also … my first question is can I use the tuner to adjust the throttle lag or do I need to get a Pedal Commander or what do you recommend? This is my first fly by wire hotrod…. My 65 Chevelle and 97 Camaro were both cable operated throttles. Also looking for any recommendations on software I should be getting on my laptop if needed and or anything else I should be aware of? Thanks for your time and any input
-Shane
New to Tuners and Throttle Controllers
Re: New to Tuners and Throttle Controllers
do you know if its a standard i3 or PC-3000?
9 digit serial starting with 20X will help.
its a procharger tool, so it wont have any parameters in it for adjusting anything. You can consider a custom tune to get ore out of it if you wish.
