Canned tune emailed?
Hello, I am curious if the canned tunes preloaded on the devices are able to be emailed. I currently have a 97 mustang GT with an 03 GT motor and if for the time being I would be able to get one of the canned 87/91 tunes preloaded on the device to download onto my tuner until I can find a cmr tuner close once I add boost. “Trinity t2 ex platinum”
Last edited by maximusstryker117 on Wed Jun 07, 2023 4:09 pm, edited 1 time in total.
97 Mustang GT 03 4.6 2V 5 Speed
Re: Canned tune emailed?
what pcm is in the vehicle?
tech@diablosport.com
It is the 97 pcm as I am running the same harness from before the swap. So npi harness/pcm.
OK, a tune from an 03 will not go in that pcm. What you need is a custom tune specific to the 03 motor for your 97 pcm.
Okay, Thankyou. Where is the tool that use to be up I could locate a CMR tuner near me. I don’t know that I have many around for a dyno besides diablosport dealers.
Lima Ohio 45806
try southern speed inc, he should be able to dial it in via email no problem
