7202 issues?
Discuss Predator 2 for GM vehicles.
Postee2120
7202 issues?
Post by Postee2120 »
got a 7202 and i used it on one silverado. after awhile i reset that one to stock and went to use it on another silverado and it kept putting me through a turn key ignition on loop. i know it can only be used on 1 at a time but i thought you could return it to stock and use it on a 2nd vehicle. any info or thoughts on this is appreciated. it lets me select tune then the ignition on screen then goes through to is this the same vehicle as last time and i select no then it resets and does it all over again
Re: 7202 issues?
try this
connect to the truck with the ignition OFF
go to the tune menu, and it should eventually prompt you to reselect the vehicle.
Pick the correct Y/M/M and let it reboot and it should work from there.
If not please give us a call to sort it out, 561-908-0040
Postee2120
Re: 7202 issues?
Thank you mike will try after work
Return to “Predator 2 for GM”
