Trinity 2, Dataviewer and AEM Ugeo wideband
Suivensports
Post by Suivensports »
Hi there,
I have 2019 Dodge Challenger Scat Pack with the Diablosport Trinity 2. Recently I installed the AEM Uego Wideband, and I added the new PID to the Trinity 2 with the right scaling so I have the same AFR value on the AEM gauge as well on my Trinity. My problem is I can not add the EAS AFR PID to the Dataviewer for data logging. Dataviewer shows the EAS tree but the chanel A analog signal there do not correspond with the scailing I have. Is there something else I need to do in order to have the right AFR PID added to the Dataviewer?
Re: Trinity 2, Dataviewer and AEM Ugeo wideband
can you please try this with DV2 and if it doesn't show, please attach the log file.
Suivensports
Good morning, I tried before with both, DV and DV2, at least DV recognize the EAS, but the DV2 does not, even after re-query at least twice, that is why I didn't logging using DV2. Attached you will find: the picture of the availables PIDs on DV2. A log using DV. A log using the Trinity 2 screen and the dashboard file I was using for the Trinity 2 HMI. I'm sorry, my be I'm wrong but I didn't see the point to do the log using DV2 if the PID wasn't there, please, pardon me if I wasn't right and let me know if you want the log anyway.
Trinity2_AFR.dsh
(2.56 KiB) Downloaded 90 times
EAS AFR Trinity2 screen.log
(747.7 KiB) Downloaded 83 times
EAS AFR Dataviewer.log
(338.3 KiB) Downloaded 95 times
DV2 PID options.png (55.1 KiB) Viewed 2963 times
Just to confirm, are you logging to the T2 and trying to play back on the PC, or trying to stream to the PC?
Suivensports
I'm trying to stream and log to the PC.
The T2 was just to show you that the EAS AFR is working.
Thank you for your help.
Suivensports
Does diablosport dataviewer has a windows operating system requirement?
Because I'm using Windows 10.
win10 is fine
Suivensports
Good mornig, Any idea on what can I do or try?
OK, for now streaming the EAS devices is not supported, you'll want to record the logs to the device then play them back on a pc.
