I have a 2010 escalade. I am currently using the p2 tuner to make a couple of changes using the stock w/options menu. I have disabled AFM/DOD. Added +50 RPM to idle and park. Turned on Diablo fan setting.
I have noticed the Upshift Torque setting is enabled. Is this a stock setting? Can someone explain it better in layman's terms? My main concern is transmission longevity. Should I leave it enabled?
Also, happy to hear some more feedback on my current settings.
Thanks!
Question about Upshift Torque setting
Re: Question about Upshift Torque setting
this allows the pcm to modulate torque on WOT upshifts to help extend trans life. Disabling it will allow the engine to make full torque through the shifts.
tech@diablosport.com
Thanks for the response!
If my main concern is transmission life, I should leave it enabled?
yes
