USB/SERIAL adaptor for vista 64 bit?????
vfrinterceptor
Post by vfrinterceptor »
my computer is not reconizing the usb.serial adaptor i tried loading some drivers but none of them work. does anyone know where i could load one for vista 64 bit?
ches111
RE: USB/SERIAL adaptor for vista 64 bit?????
Post by ches111 »
vfrinterceptor,
You might try asking your question on a site called xcpus.com
That is a group of people that are hardware enthusiasts that may already have your answer.
Xcpus.com
or
Xtremecpus.com
It is a great site with good people.. If you are running Vista 64bit version then likely you will fit right in :)
Also, don't be afraid to register.. The site is basically the replacement for what Toms Hardware used to be.
I am the Consumer Electronics Guru for the site (think editor/reviewer) :)
07 Chevy Silverado w6.0L Vortec Max, U7194, AEM Brute Force
Or, try the DSDL section here, our windows guy is pretty good with these issues...
vfrinterceptor
im outta luck
Re: RE: USB/SERIAL adaptor for vista 64 bit?????
vfrinterceptor wrote:im outta luck
How so?
Did you post up in the DSDL section?
I have never seen one of these issues go unsolved...
johnc
RE: Re: RE: USB/SERIAL adaptor for vista 64 bit?????
Post by johnc »
He did already. I couldn't help with this.
johnc <at> diablosport.com
johnc
Post by johnc »
This is risky, but if you have a prolific cable you could try the XP 64-bit drivers here:
http://www.diablosport.com/index.php?na ... 4935#24935
vfrinterceptor
i have vista 64 bit .no drivers serial adaptors for vista 64 bit i contacted microsoft
Return to “Predator GM Gas”
