I3 8300 won’t turn MDS off 13’ ram 1500
Hunterw16
Post by Hunterw16 »
It will not let me upload the video but if I go under modify and go to turn MDS off under advanced tuning even if I hit off and hit the yes button, it still goes back to MDS on. Anyone else have this issue?
Re: I3 8300 won’t turn MDS off 13’ ram 1500
you set it to off then save the change?
if so just back out and select apply tune, it should be off.
keithw923
Post by keithw923 »
Hunterw16 wrote: Tue Aug 08, 2023 8:44 pm It will not let me upload the video but if I go under modify and go to turn MDS off under advanced tuning even if I hit off and hit the yes button, it still goes back to MDS on. Anyone else have this issue?
I have the same problem happening on my 2012 1500. I select off and save then when I check back it says on still.
keithw923 wrote: Tue Nov 07, 2023 6:51 pm
if you turn it off then load the tune, its off. The default selection in the menu is on, hence you'll always see ON highlighted, but that is not an indication of the currently programmed status in the pcm.
