Predator U737 Update oder looked??
RainerH.
Post by RainerH. »
Hello, I have a Predator U737.
Now I wanted to deactivate the MDS on my 300c, but I can't get into the tunes.
The following message: Predator does not Support. Tool Update might be available.
Do I have to do an update somewhere to make it work, if so how? Or is the given number a chassis number that does not match the car?
Re: Predator U737 Update oder looked??
tough spot, the dsdl server is no longer active so the only solution here is to find someone who can flash your PCM to the required calibration ID, or consider trading it in toward a new device for 25% off.
RainerH.
Post by RainerH. »
Ok aber wie soll das funktionieren mit dem Flashen mit der ID?
Heißt mir bringt der Updater und Windows XP gar nichts, bzw das Gerät ist nutzlos für meine Vorhaben das MDS zu deaktivieren
Return to “Ignition updater”
