USB/SERIAL adaptor for vista 64 bit?????
vfrinterceptor
my computer is not reconizing the usb.serial adaptor i tried loading some drivers but none of them work. does anyone know where i could load one for vista 64 bit?
RE: USB/SERIAL adaptor for vista 64 bit?????
vfrinterceptor,
You might try asking your question on a site called xcpus.com
That is a group of people that are hardware enthusiasts that may already have your answer.
Xcpus.com
or
Xtremecpus.com
It is a great site with good people.. If you are running Vista 64bit version then likely you will fit right in
Also, don't be afraid to register.. The site is basically the replacement for what Toms Hardware used to be.
I am the Consumer Electronics Guru for the site (think editor/reviewer)
Xcpus.com
or
Xtremecpus.com
07 Chevy Silverado w6.0L Vortec Max, U7194, AEM Brute Force
Or, try the DSDL section here, our windows guy is pretty good with these issues...
vfrinterceptor
im outta luck
Re: RE: USB/SERIAL adaptor for vista 64 bit?????
How so?vfrinterceptor wrote:im outta luck
Did you post up in the DSDL section?
I have never seen one of these issues go unsolved...
RE: Re: RE: USB/SERIAL adaptor for vista 64 bit?????
He did already. I couldn't help with this.
johnc <at> diablosport.com
This is risky, but if you have a prolific cable you could try the XP 64-bit drivers here:
http://www.diablosport.com/index.php?na ... 4935#24935
vfrinterceptor
i have vista 64 bit .no drivers serial adaptors for vista 64 bit i contacted microsoft
