Hesitation off the Line
titleistmover
Post by titleistmover »
I have an 07 Mustang 4.0 V6 with the Airaid Intake and the Magnaflow Cat Back Dual pipe system. I downloaded the 91 Octane Airaid Performance tune and I am finding a big hesitation off the line. Should I re-program it or try something different. Also, I have been reading some of the posts and I am wondering about a firmer shift. Any suggestions?
RE: Hesitation off the Line
Have you removed the venturi in the Airaid.
titleistmover
as far as I know, everything is set up as indicated.
kmac1
Post by kmac1 »
If you are on the latest revision for this tool then you should have the option of using the firm shift tune for the AirAid. If you still have the hesitation you can email me a copy of the tune that is in the car by exporting the last tune written. That would allow me to see exactly what the Predator is writing to the PCM.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
titleistmover
Kevin, thanks for your reply. I don't have the option of using an "Airaid" firmshift tune. Are there intsructions on how to export my tune and e-mail it to you? As for the venturi...should I remove it?
Return to “General Questions”
