Hi,
I got a used i3 tuner I installed updates plugged it to my car it said will calibrate my 2014 chrysler 300 srt8 with the 6.4 litre v8 now the engine light stays on I've tried to clear it but nothing I would like to know what's happened thanks.
Tokstylz
Engine light
Re: Engine light
use the device to read the code and see what it says, and clear it and see if it comes back.
Re: Engine light
Hi mike yes tried that but no it come back but when I first put connected my tuner it ask if I wanted to recalibrate I pressed yes and ever since the light come on I took her in to a tune shop today and the light is still on.mikel wrote: Thu Aug 31, 2023 11:29 am use the device to read the code and see what it says, and clear it and see if it comes back.
Re: Engine light
what is the code?
its likely telling you there is an actual issue somewhere.
Re: Engine light
PCM P0038 HO2S HEATER CONT, PCM P0058HO2 HEATER CONTmikel wrote: Wed Sep 06, 2023 11:57 am what is the code?
Re: Engine light
you have an issue with an O2 sensor that must be dealt with.
Re: Engine light
I changed the sensors and the light came back on I'm wondered I run the car on 98 fuel if this has something to do with this problem it run fine for 2 years before the update.
Re: Engine light
could be a harness issue, heater control, best to properly diagnose rather than replace. I assume you are in europe? 98 is fine.
Re: Engine light
Queensland Australia.mikel wrote: Tue Sep 19, 2023 4:28 pm could be a harness issue, heater control, best to properly diagnose rather than replace. I assume you are in europe? 98 is fine.
