Jeep Wrangler 3.6 cut off rpm
Re: Jeep Wrangler 3.6 cut off rpm
Yes wrote:please tell me how!
at least in neutral
Load this, reset the parameters when the tool asks you to do so.
pcm_68149808ac_perf_rev_limit.drg
(72.17 KiB) Downloaded 240 times
tech@diablosport.com
Yes
Post by Yes »
at least in neutral
That's awesome!
Thank you Mikel very much for your support.
francorotunnoc
Post by francorotunnoc »
this works for a intune in a jeep jk 3.6 2012??
opeth302
Post by opeth302 »
Hi mikel I have same issue about rising rev limiter in natural or drive
I'm having trinity
JK 2013 3.6 manual Trsnsmision
I want rev limit at 4000k at least in Natuaral Gear
PCM_68149834AC_Perf_91oct_modified.drg
(2.25 KiB) Downloaded 150 times
PCM_68149834AC.drg
(93.54 KiB) Downloaded 175 times
the neutral limiter is set to 5500 in the file you posted there....
bnsagan
Post by bnsagan »
Hello, I have a 2014 Jeep Wrangler Rubicon with an automatic transmission. I cannot program the manual gear when it is in gear No. 1. It switches to gear No. 2 during turns. I want to install it to control it manually.
there is limited ability for trans tuning on that application unfortunately.
bnsagan
إعادة: جيب رانجلر 3.6 قطع دورة في الدقيقة
Post by bnsagan »
Good day
I am talking about gear changes when they are in the normal gear mode and I use off-road driving with rear-wheel drive and not four-wheel drive. In the 2012 model, this feature is manually controlled, while in models 2013 and above it is not possible and it is software. Can the Diablo Sport Platinum Torney EX Do that ?
I'm not exactly sure what you are asking?
bnsagan
Post by bnsagan »
Jeep Wrangler model 2012 The gearbox is automatic when you are driving off-road and you use +/- in drive mode and you put it in gear 1 normally and not automatic with the rear-wheel drive system. It cannot be switched on its own to gear 2 while in the 2014 model it automatically changes from 1 to 2 with the same drive mode. Does it? This can be programmed with Diablo
