Engine light
tokstylz
Engine light
Post by tokstylz »
Hi,
I got a used i3 tuner I installed updates plugged it to my car it said will calibrate my 2014 chrysler 300 srt8 with the 6.4 litre v8 now the engine light stays on I've tried to clear it but nothing I would like to know what's happened thanks.
Tokstylz
Re: Engine light
use the device to read the code and see what it says, and clear it and see if it comes back.
tech@diablosport.com
tokstylz
Re: Engine light
Post by tokstylz »
mikel wrote: Thu Aug 31, 2023 11:29 am use the device to read the code and see what it says, and clear it and see if it comes back.
Hi mike yes tried that but no it come back but when I first put connected my tuner it ask if I wanted to recalibrate I pressed yes and ever since the light come on I took her in to a tune shop today and the light is still on.
Re: Engine light
what is the code?
its likely telling you there is an actual issue somewhere.
tokstylz
Re: Engine light
Post by tokstylz »
mikel wrote: Wed Sep 06, 2023 11:57 am what is the code?
PCM P0038 HO2S HEATER CONT, PCM P0058HO2 HEATER CONT
Re: Engine light
you have an issue with an O2 sensor that must be dealt with.
tokstylz
Re: Engine light
Post by tokstylz »
mikel wrote: Thu Sep 07, 2023 9:13 am you have an issue with an O2 sensor that must be dealt with.
I changed the sensors and the light came back on I'm wondered I run the car on 98 fuel if this has something to do with this problem it run fine for 2 years before the update.
Re: Engine light
could be a harness issue, heater control, best to properly diagnose rather than replace. I assume you are in europe? 98 is fine.
tokstylz
Re: Engine light
Post by tokstylz »
mikel wrote: Tue Sep 19, 2023 4:28 pm could be a harness issue, heater control, best to properly diagnose rather than replace. I assume you are in europe? 98 is fine.
Queensland Australia.
