solenoids disconnect or bot
baychef
Post by baychef »
grasping at straws right now ive done a full afm delete on a 2018 chevy silverado 1500 it all went very smooth sdpc kit with a 6.2 cam upgrade we cant get rid of 2 codes p0430 and p0420 cat type shit the o2 is within spec up and down as are the cats, so we removed tune altogether and ran in manual to avoid it trying to go back into 4v due in part to plugging solenoids back in during instal. .there are NO. CODES IN STOCK, but add afm disable in modify stock parameters and those 2 codes come back, so im asking for any advice in this area , TECH IN HERE HAS LEFT ME HANGIN AFTER NUMEROUS ATTEPTS TO GET SOME EFFEN HELP so solenoid under valley plugged in or no ? the i3 IS THE PROBLEM
Re: solenoids disconnect or bot
can you please load the tune then grab a copy of the last tune written file from the device and post it here so we can check it out?
