On the trinity under knock retard there is a smaller window
Bottom. Looks like. 00/00
Is the numbers on the left side that show in negative timing being added and the right
in positive a knock?
Example. -25/.50 Is this 1/4 deg timing added along with 1/2 deg retard or knock?
Lol hope I asked this correctly
thanks.
John
reading the knock sensor
Re: reading the knock sensor
-25 would be pulling 25 degrees. .50 would be adding .5 degrees.
Insert Clever comment here...
So all numbers at the bottom left side of the knock guage be counts of knock?
I will attach a couple data logs for you to look at latter tonight if you have time
Yes please. So I can make sure we're on the same page.
here you go there is two
logs... how much knock, timing retrd and advance are you seeing
- prt thro knock.log
- (369.48 KiB) Downloaded 425 times
- NOC_NEW.LOG
- (49.96 KiB) Downloaded 337 times
here is a log with the same set up with no knock
just a different tuner that wrote tune
why is the knock dead quiet are the sensor turned on?
i have included a copy of the tune file
JOHN
JOHN
- _93Octane.frg
- (546.04 KiB) Downloaded 330 times
- TEST014 on ramp.log
- (2.03 MiB) Downloaded 324 times
The knock sensor is in fact off in that tune you posted.
On the other logs what did you determine for knock counts and timing retard or advance
thanks
thanks
At 7:15 is adding .75 of a degree
At 7:19 is taking out .25 of a degree
In that tune you posted, the knock sensor is indeed malfunctioning. retro bowl college
