C&L
chrissmithcthomes
C&L
I have a U7140 for my '05 Mustang GT. I have the C&L Racer Kit along with a throttle body and throttle body spacer, Long tube headers, X pipe with high flow cats and 3.73 gears. First question, I noticed you removed the c&l tunes with the new revision. Is the temporary or will I never be able to updated the tuner again. Also, with my other mods listed above, minus the gears (I know what to do there), should I tweak any of the numbers. It just doesnt feel all there at the lower rpms. Also, the c&l racer firm shift tune throws o2 codes saying too rich and stuck open but not in the c&l racer tune. Please help me out.
RE: C&L
Not sure about those codes, both of those tunes should use the same MAF transfer function.
The new revisions will no longer have the C&L tunes, but you can export them to a PC and keep them as custom tunes...
Re: RE: C&L
what do we do to get the tune for the C&L intake??mikel wrote:Not sure about those codes, both of those tunes should use the same MAF transfer function.
2005 Mustang GT, CNL cold air intake, Diablo Sport CNL Tune, Flowmaster 40 Exhaust, Pullies.
C&L Predator Tune
CL7140 - 105536
v.8r16
2005 Ford Mustang GT
I just read that if I update my Predator I will loose the C&L tune.
1.Is the C&L cold air intake still supported by DS?
2.Does the new ver 05-9r01 take into account that the C&L cold air intake is still installed on the car?
3.Is there a 100 hp tune available for the stock motor?
Lou
v.8r16
Lou
Re: C&L Predator Tune
1. Yes, in the CL7140 Predator.LRL105 wrote:CL7140 - 105536
v.8r16
Lou
2. No, it does not have C&L tunes.
3. Huh??? No.....impossible.
100hp tunes are for diesels only.
RE: Re: C&L Predator Tune
OK. So when I upgrade my CL7140 - 105536 to ver 05-9r01 I need put the factory tune back in the car then export the C&L tune to my PC, then do the version upgrade and import the C&L tune back into my predator and save it as a custom tune to be put back into the car.mikel wrote:1. Yes, in the CL7140 Predator.LRL105 wrote:CL7140 - 105536
v.8r16
Lou
What is in the new ver 05-9r01?
Lou
