I have predator p2 u7202. It worked fine before I did an update to r69. Now my tuner doesn’t work, the update didn’t update correctly.
I removed the tune from my now parked for the season vehicle (2016 Silverado 5.3) then did an update to the tuner which I thought went smoothly. I then tried to tune my winter vehicle (2007 Tahoe 5.3) and noticed right away that the tuner wasn’t working the same ... at the tune screen when I hit ok it starts reading my truck right away with no tune select options. When it does it’s thing it says database error, update device and reboots. I later check the device info and it says status upload failed and vehicle info shows the vin from my other truck. On the ignition update program it shows status: upload failed and my silverados vin tune level: 0 installing: r247 (0 files)
I reconnected to my Silverado to see what it would do and it does the same thing as my Tahoe. When I hit tune it starts reading the vehicle without the tune select screen and when done says database error, update to tuner required. Checking vehicle info now shows 2 vehicle OS numbers and says it’s on a stock tune.
I need help to first fix the tuner so it can be properly updated with the fixed database. Then I need to see if my Silverado was actually reverted back to stock
Predator 2 problems
Re: Predator 2 problems
Please provide the serial number off the device so we can look into this.
Stars with 20X, 9 digits.
201296452
Thank you very much, past 2 days have been very stressful.
please connect to a pc and update twice in a row with the update agent software then it should work as expected.
Thank you, I will try tonight.
Hi, I did as you said. the first update loaded which was a reset file. After that, I restarted the ignition program and the VIN lock: upload failed was still there with my Silverado's VIN. I proceeded to download and install the next update which was 514 files successfully. I restarted ignition again just to check status's and if there were more updates and the VIN lock: upload failed was still there with my Silverado's VIN. It said there was another update for 514 files again so I downloaded and installed that successfully too. I restarted ignition and a different update was available which is the same one from 2 days ago that caused this mess ... that installed successfully. I check again and again with installs of the same last update. every time I check with ignition it tells me there is an update ... it's always the same.
Is there a way to do a clean wipe and factory reset?
Shouldn't I delete the old files on the tuner before starting the updates?
Its just reloading the file we locked it to, it should be good to go in the vehicle now.
I just tried it in my Tahoe and all works again. Thanks so much.
good deal, enjoy.
Mavericksierra7
mikel wrote: Wed Oct 02, 2019 12:45 pm Please provide the serial number off the device so we can look into this.
Trying to use it on 2017 gmc sierra 5.3
Ill pay the 40 if anything for the code
