Johan, your turn... stock timing/spark table in the tunes??
Hey Mike/Johan...
does the 91 octane tune in the U7191 for my 06 Monte use the stock timing tables, or are they still advanced a little?
If it DOES use the stock timing/spark settings, then what changes are made to the tune to make it any better than the stock setup?
And for the Diablo 93 octane tune, what do you have the timing/spark set to for WOT... 28* ?? And is it 28* in all 3 rpm ranges?? Just wondering so that I know if/when I pull some timing from the ranges, how much will actually be pulled.
Thanks!
-Lew
Thanks!
-Lew
RE: stock timing/spark table in the 91 Octane tune??
Not sure where the timing is set in those tunes, but most of the power is found through leaning out the fuel mixture.
I'm sure Johan will chime in with the specs.
ok cool... thx Mike...
Oh Johaaaaaaan....???????
bump....
Thanks!
-Lew
Thanks!
-Lew
nothing?? anything??
Give him some time, he's a busy cat these days....lots of new stuff coming.
cool! I hope tranny support for the U7191 2006 Monte Carlo SS is one of the new things coming! ...and then the personal CMR software after that...
those should be the 2 priorities for you guys right now...
bump for today...
yeah, I can see I'm gonna have to start leaning a little harder on 'em around here...
He he, i got lost for a while in diesel smoke, finally found my way back inside.
The 91 octane tunes do have stock timing, however the IAT timing table is modified a little not to pull so much timing based on IAT.
Also the TM is addressed and then the biggest thing which is the 4sec PE fuel delay, which waits 4 seconds to give you fuel when you romp on it. We also lean it out a little as well as allow for quicker PE mode via %tps. Hmm, did i forget something, oh yeah we also engage the flux capacitor overdrive.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
thanks man!!
yup, forgot something... how about this:
And for the Diablo 93 octane tune, what do you have the timing/spark set to for WOT... 28* ?? And is it 28* in all 3 rpm ranges?? Just wondering so that I know if/when I pull some timing % from the ranges, I know how much will actually be pulled.
Awesome, that's what I wanted to know... Thanks Johan!!!
Next time I'm down in Florida, I'm gonna stop by and get you guys a couple beers!! and maybe even let you guys see if you can get some more power outta my baby with a tune! (before the beers though)
Thanks again guys!
-Lew
Thanks again guys!
-Lew
