New PCM, Existing T2, can’t download tune
aitken08
Post by aitken08 »
2007 Ram 1500 5.7
I have been utilizing the Trinity2 for 2 months now, everything was working properly until I purchased a new PCM for the truck. The previous PCM accepted the tunes just fine and updated just fine.
After disconnecting battery, installing new PCM and then reconnecting battery, I attempted to download the tune onto the new PCM and the T2 states that it does not recognize new PCM.
The PCM is preprogrammed with my trucks VIN so it’s plug and play application, how do I get the T2 to recognize new PCM in vehicle so that I can download my tune?
Re: New PCM, Existing T2, can’t download tune
had you returned the stock tune to the previous pcm before you made this change?
aitken08
Post by aitken08 »
mikel wrote: Mon Apr 08, 2024 11:20 am had you returned the stock tune to the previous pcm before you made this change?
No I did not, I will give that a try
that should do it.
aitken08
Post by aitken08 »
mikel wrote: Tue Apr 16, 2024 4:51 pm that should do it.
I disconnected the battery, reinstalled the original PCM and reconnected battery, and my Diablo sport is still saying it does not recognize the device. The message on the screen states that I should “connect device to PC and run the Update Agent client to download the update”
How do I do set that up and use the update client?
something isn't adding up, best to give our support team a call to get this figured out, 561-908-0040
the update agent software can be downloaded from the 'downloads' page on our website.
