bypass module
loisrogers
bypass module
Post by loisrogers »
Hi - need some quick help if anyone can answer, much appreciated. When installing Unlocked PCM into 2019 Challenger 5.7 Hemi, is a security bypass module required, or does that apply only to trucks and not the Challenger. Got replacement PCM with Security Bypass cable, and i-3 tuner is on the way. So, I think that for the Challenger, a MODULE is not required, but instead, only the security bypass cable. Please let me know if this is correct. The instructions we received are scanty- and then got better instructions off of a posting in this forum that suggest the Module is not used for Challenger applications. Thank you. Lois
Re: bypass module
all 19s require some form of bypass.
the cars use the cable and the new rams and Jeep JL/JT use the module (box).
loisrogers
Re: bypass module
After installing on 3 Rams, we've gotten pretty good at this but wanted to make sure we understood bypass cable OR module, that is, one or the other. This is not clear in any of the instruction sheets we got. We received one instruction file that had trucks and cars all on the same photo mixed together - impossible to understand. In an effort to get it right, we tend to make things harder than they are. Once you've installed a PCM and a tune, it's cake. But, we changed from RAM truck to Challenger, and the tuners are all different now. these are truly fabulous products, but the instructions are BAD, WAY BAD..... confusing. Special note is that on the Challenger, removing the panel to install the cable on passenger side is not required - instead, just go in through the glove box. And, a "kick panel" is located down by one's FEET, as in KICK/Feet. A kick panel is not up above or on side panel of car. The You Tube video is pretty good but mostly you get great view of a guy's head instead of what's being plugged in and where. Anyway, great product but your instructions absolutely SUCK!!!
:mrgreen:
PNSHR1
Bypass Module
Post by PNSHR1 »
Good Evening: Mike
Could you please provide me with the part number for just the Bypass Module (Not the cable)? I am planning on sending in my 2023 Dodge Durango SRT Hellcat's factory PCM for the unlock service and then will purchase the #8345 tuner. I assume that the module would need to be purchased separately, unless it is included with the tuners now?
Please clarify and advise either way.
Thanks.
Respectfully submitted,
DLBIII
Re: bypass module
module for the durango is 18GBJ
m0onsh4d0w
Re: bypass module
Post by m0onsh4d0w »
loisrogers wrote: Tue Aug 20, 2019 12:16 pm After installing on 3 Rams, we've gotten pretty good at this but wanted to make sure we understood bypass cable OR module, that is, one or the other. This is not clear in any of the instruction sheets we got. We received one instruction file that had trucks and cars all on the same photo mixed together - impossible to understand. In an effort to get it right, we tend to make things harder than they are. Once you've installed a PCM and a tune, it's cake. But, we changed from RAM truck to Challenger, and the tuners are all different now. these are truly fabulous products, but the instructions are BAD, WAY BAD..... confusing. Special note is that on the Challenger, removing the panel to install the cable on passenger side is not required - instead, just go in through the glove box. And, a "kick panel" is located down by one's FEET, as in KICK/Feet. A kick panel is not up above or on side panel of car. The You Tube video is pretty good but mostly you get great view of a guy's head instead of what's being plugged in and where. Anyway, great product but your instructions absolutely SUCK!!!
:mrgreen:
From what Mikel mentioned, it's clear that a security bypass is necessary for all 2019 vehicles, including the Challenger. While the instructions may not be ideal, your hands-on experience and willingness to adapt will likely make the installation smoother.
Return to “General Questions”
