Jeep grand cherokee 2007 fan control
m_elkhishin
Dears
I have Jeep GC WH 5.7 2007 which has hydraulic cooling fan. I installed 180 thermostat and I need to set the fan set points to lower degree. It seems that the trinity fan control is missing for this particular model. some guys said that it can be adjusted by HP tuner application by setting the fan type to PWM and then set a parameter "desired engine temperature" to the desired degree. the stock setting is 103 Celsius and I want to change it to 95.
I own the Trinity and I hope it can support this feature.
Re: Jeep grand cherokee 2007 fan control
so is it a mechanical fan or electric?
Post the backup and last tune written files from your device please.
m_elkhishin
mikel wrote:so is it a mechanical fan or electric?
It is mechanical rotating by the power steering fluid pressure. but the ECU controls the solenoids to control the speed.
- PCM_05094636AG_Perf_91oct_modified.drg
- Current tune loaded
- (3.25 KiB) Downloaded 453 times
- PCM_05094636AG.drg
- Original Backup file
- (84.6 KiB) Downloaded 452 times
the fan settings are all lowered quite a bit in the tune, so if thats not affecting the fans its not likely something that can be controlled in the same manner as the electric fans.m_elkhishin wrote:mikel wrote:so is it a mechanical fan or electric?
m_elkhishin
Dear Mikelmikel wrote:the fan settings are all lowered quite a bit in the tune, so if thats not affecting the fans its not likely something that can be controlled in the same manner as the electric fans.m_elkhishin wrote:mikel wrote:so is it a mechanical fan or electric?
Thanks for your feed back. the following is a reply from a jeep owner on other forum. he is describing how he solved the issue. I hope that can help finding a solution.
At last got my Jeep's hydraulic fan to now work as I want.
Used HP Tuner and set the low, med/high activation temps etc, but still did not go to high speed when reaching 100 C as set.
Today went back to the guy who does my tuning and found following:
three hydraulic fan types:
1. two speed
2. three speed
3. pulsed modulated
My Jeep has the pulsed modulated and thus the low/high temp limits are not the controlling settings. There is a selection where the required engine temp must be set, then the fan will attempt to maintain this set temp. Fan speed ramps up to full speed if required to keep this set temp.
The default on my Jeep was 103 C. Brought this down to 95 C and now works like a charm.
let me see what we can find on this.
m_elkhishin
Hi Mikel
did you find any way to solve this issue?
Nothing yet unfortunately.
any word on this? i am running into the same issue and i really would hate to switch over to hp tuners since diablosport is so user friendly.
_______________________________________
2010 Jeep Commander Limited 5.7 2wd
CAI, 6.4 intake manifold, obx long tubes, custom catback, UPR catch can
Jay Greene tuned
eibach lowering springs on 20x10 SRT spider monkey's
Jay Greene tuned
Sorry to bump this old thread ,
I bought intune i3 platinum and i love it , but im kinda bummed and i feel a bit misled (i probably should've asked before i bought it ) , that i cant control the hydralic cooling fan , also transmission options are missing from the tuner , but i feel a diference in shifting .
On the official site its said that the device supports those options for the specific model ( jeep wk 2005-2010) but in reality it does not
can you post the info.xml file from your i3 drive?Madnesst wrote: Wed Jun 19, 2024 1:27 pm Sorry to bump this old thread ,
attachedmikel wrote: Thu Jun 20, 2024 10:31 amcan you post the info.xml file from your i3 drive?Madnesst wrote: Wed Jun 19, 2024 1:27 pm Sorry to bump this old thread ,
- info.xml
- (3.09 KiB) Downloaded 76 times
let me do some digging.
