07 Charger SRT8 lazy off the line
Need help. U7135 with 9r04 I am using Shell Vpower 91 octane (thats the highest octane I can get).
I have an 07 charger SRT8 with K&N CAI, 180 thermo & BT catch can.
I have been using the 91 octane CAI performance tune and since installing it I can no longer spin the tires from a stop when I floor it (autostick in 1, ESP off, TCM adaptives reset, tranny in mode 3).
I have done a lot of data logging and have eliminated all ST & LT knock by adding fuel 10% 12% 12% in the 3 ranges. Also, the throttle shows it going to 127.1%.
I tried just the 91 octane tune and had a lot of ST & LT knock. I had also tried fuel at 5% 5% 5% with retard set to 0 -2 -2, still no ST or LT and still cant spin the tires. My 0-60 varies between 5.34 & 5.78 with these tunes.
Were I live the elevation is 2900'
The car seems to start slow then picks up real quick after I floor it from a stop.
Any of you guys out there with a similar setup, let me know what your tunes are. I included one of my logs if your interested.
RE: 07 Charger SRT8 lazy off the line
mine is the same way with the newer crom. I miss the earlier versions.
I have almost the same setup on my 07 300 SRT8, running on a Johan tweaked 9R04, except an aFe Stage 2 intake running on Exxon or Mobil 93. She runs consistant 4.60-4.80 second 0-60s. When he first fixed my tune the throttle response was awesome. Unfortunetly, that was short lived. The computer learned the new parameters and its back to being a slug off the line unless you floor it.
xegitalian19xx
here is some reading info if you are interested....
http://www.chargerforumz.com/showthread ... t=sluggish
There is a lot of useful information on these forumz & a hell of a lot of good people to help you out....check it out!
I'm asking the same thing about my 07 R/T. I only have the new revision and waiting to install the 93 CAI tune. Step on the gas sluggish then wham fast acceleration.
ALot of it is due to the tranny instantly shifting to second gear unless you hit a certain throttle position. Then when you hit it after getting off the line it will kick down and launch. The early versions were nasty with the SRT8s. The tranny wouldn't kick down until like 85-90% throttle and then when it did, the tires would break loose.
Well I tried doing the computer reset (pull fuse #11 etc) and that seemed to help.
The car seems more responsive when I stomp on it from a stop.
I thought that when you upload/modify a diablo tune it resets the computer.
If so DIABLO, why does the pulling fuse 11 computer reset make a difference ??
Because pulling fuse 11 resets the adaptives not the computer.
try a cmr tune ........i just got my tune yesterday an the tuner addressed all the issues with tranny and everything else i disliked and its a huge difference compared to my old can 16a tune bigtime .
06 Charger SRT8 inferno red with predator (my tune) ,mopar cai ,180 stat........ 12.7 @ 110 and currently 81,000 miles
06 TBSS AWD all stock for now......
08 Jeep Wrangler 4DR redrock w/AEV 6.1 hemiswap and a long list of mods ........
So, if i install a new or modified tune I will have to reset the adaptives every time?
This is contrary to what I was told by diablo. Why isnt this in the Diablo documentation ?
You don't have to reset anything. Reseting them just makes the computer forget what it knows about how you drive. If you drive alot in traffic, it adapts to that, slowing throttle response, and then when you wanna hammer it, it gets a little confused and gives response as if its still in traffic.
So other than resetting the adaptives, how do I get it to forget that I dont want a slow throttle response anymore.
Beat on it. Then it'll learn new adaptives
I thought you could reset the adaptives from the Diablo.
so regardles the car will adapt ? Always??
