DataViewer 2 Datalog is very slow
Vogtj95
Post by Vogtj95 »
Hello,
I'm having a problem with my logs on the DataViewer 2 software.
So when recording a log, everything is working as it should and all my PIDs are accurate. But when I save the log and Re-open it (or Send it to my tuner) the logs are in like slow motion. My tuner said the logs are too slow and not portraying in real time.
Re: DataViewer 2 Datalog is very slow
can you post one of the logs you saved here so we can open it and try to replicate the issue?
bekeanloinse
Post by bekeanloinse »
Vogtj95 wrote: Tue May 16, 2023 12:57 pm Hello,
So when recording a log, everything is working as it should and all my PIDs are accurate. fnf But when I save the log and Re-open it (or Send it to my tuner) the logs are in like slow motion. My tuner said the logs are too slow and not portraying in real time.
Ensure the log file format is supported both by DataViewer 2 and your tuner’s software. If there are any compatibility issues or if the format used introduces delays during playback, it may cause the logs to appear "slower."
Return to “DataViewer”
