Can I use my i3 to pull timing for my NX 100 shot? I'm using 93 octane and want to start with about a 4 degree retard in timing.
Any suggestions are welcome.
Pulling timing for 100 Shot
Re: Pulling timing for 100 Shot
Yes!
Pull it from any rpm range at WOT where you'll have the nitrous activated. If using the tune, keep in mind it likely adds 2* over stock to start with.
If you have a 91 tune, it generally uses stock timing levels, so best tp start with that and pull from there.
