i3 Platinum - Read failed error when trying to install 87 octane Tune
JEBusch
Post by JEBusch »
I bought this DIABLO INTUNE I3 PLATINUM (DBL-8345) Purchase date 10/10/2023.
I have tried unsuccessfully for two weekends now to install several different “Tunes” (unmodified tunes) with no success on my 2014 Ram 1500 5.7 hemi.
It does do a backup of the stock tune, but when it tries to install a Diablo standard Tune (87 octane) it errors out with a “Read Fail” every time. Then the Truck will not start (dead). I unplug the tuner and plug it back in and get the message ( tuner in recovery mode etc..) and does do a restore of the Stock tune with success. I’ve tried everything I found on Diablo’s Forum concerning this error while trying to install a 87 octane tune to no avail.
Please advise,
Re: i3 Platinum - Read failed error when trying to install 87 octane Tune
this generally indicates the pcm was previously tuned with something else that changed the bootloader and didn't put it back. do you know if it was previously tuned with something else?
JEBusch
Post by JEBusch »
I am the original owner of this truck and bought it brand new in 2014. This is the first time for me to use the tuner and bought it from Summit racing on the 10th of this month. I purchased it to turn MDS off. Thanks...
JEBusch
Post by JEBusch »
...BUMP
Before I call and get an RMA from Summit Racing...
JEBusch
Post by JEBusch »
Just got an RMA from Summit Racing. Thanks for you limited response...lol
Apologies. Sorry to hear that, the alternative was going to likely be sending the pcm here to have us check and correct the bootloader. Best of luck if you choose a different solution.
bekeanloinse
Post by bekeanloinse »
Verify that your truck's battery is fully charged. Low voltage during the tuning process can cause "Read Fail" errors. Ideally, connect the vehicle to a battery charger during the tuning Retro Bowl College process.
Perform a hard reset of the tuner. (Refer to the user manual for specific steps.)
Retry the tuning process in a well-ventilated area with no interruptions to the power supply.
Return to “General Support”
