2024 LT1 soft rev limiter
Is there a way to remove or at least increase the soft rev limiter on my 2024 Chevy Camaro LT1?
Re: 2024 LT1 soft rev limiter
you asking about the neutral limiter?
they are there for a reason...though we do allow for raising it by +600 RPM.
Custom tuning can have it set anywhere you like it.
Can you make it so that I can raise it to what want? It’s so stupid to have a car making almost 500 horsepower and when someone pulls up to you at a light and rev there car mine will only go to 2000rpm.
I didn’t see anywhere I could raise neutral limiter by 600rpm either.
the rev limit param should have 2 settings, one for park/neutral and the other for in drive...unless this is a manual trans?
as mentioned we only allow setting the park/neutral limiter 600 rpm higher than stock to keep people from blowing stuff up...but you can have it changed in a custom tune to be whatever you wish.
