Hello!
My T2 times out whenever I try Wi-Fi setup. I had it set up previously.
I updated successfully using Update Agent, but it still times out on Wi-Fi Setup.
Check for Updates returns an error message that lets me choose WiFi setup, which times out at Gathering WiFi Information.
Currently installed modules:
application-gui 3r07r
databases-gui
dbnames 2r01f
DCX-pid 2t01vg
DCX-tune 2t03fc
dte 2r01a 2r01a
FORD-pid 2t01tc
GM-pid 2r01t
installer 2r02m
logger 2r01u
system-config 3r01s
system-rev 2r01b
updater 2r02b
vehicle 4t01at
vin 2r01r
Help!
James
WiFi Setup times out
2006 Magnum R/T - 5.7 Hemi with MDS deleted
Re: WiFi Setup times out
fails on the same network each time, or have you tried more than one network?
I've tried it away from all WiFi networks, and it still times out, but the situation has changed. Now. whether or not I'm in WiFi range, trying to access the gauges yields a screen in an endless loop, which states:
TURN IGNITION ON OR PUT INTO RUN MODE
DO NOT START THE ENGINE!
PRESS SCREEN TO CONTINUE
It's just not fair to get more problems when I haven't dealt with the first one yet!
James
James
and this is a new issue, the gauges have worked previously?
Yes, I've been using the gauges for a year, and changing them occasionally.
I thought that it might be a communication issue, but the readiness test works.
James
James
could it be that something is touching the screen forcing it into a menu?
Might be good to call our team, 561-908-0040 and let them troubleshoot it.
I've been using the same rear mount since I installed it, and there's nothing else touching the case or screen. I'm able to navigate through the other menus normally.
Thanks for the recommendation, I'll give support a call in the morning.
I appreciate your help.
James
James
Good news, everyone!
While browsing the Settings menu, I came across the entry "Restore Default PIDs."
So, for no reason other than it was there, I used it, and lo and behold, the gauge screen now loads and operates. So that's one problem resolved.
Now, I have to rebuild my gauge screens from scratch, and my goodness, you guys have been busy! There are many dozens of new PIDs that I've never seen.
In the past, I have gone through the PIDs offered and made my own list. That wasn't so bad when there were only a couple hundred of them. A typical record that I generated looks like this:
So if there happens to be a list available, it would sure save me a lot of work!
I then had the thought that "Restore Default Settings" might make the WiFi settings screen work again, but that didn't work, so I'm still going to call support in the morning. Nice try, though.
James
Code: Select all
Src Dec Hex Basic/Adv Desc Heading Sub Label Units Warning WarnM Alert AlertM Lo/Hi Min MinM Max MaxM Min MinM
PCM 773 305 Adv Voltage reading from Knock Sensor 1. Knock Control KNKSNSV1 KNKSNSV1 V 4.0000 - 4.5000 - Hi 0.0000 - 5.0000 - 0.0000 -I then had the thought that "Restore Default Settings" might make the WiFi settings screen work again, but that didn't work, so I'm still going to call support in the morning. Nice try, though.
James
pid list varies by vehicle and pcm type, so its tough to provide that
I called tech support. A woman told me not to use WiFi on the device.
Truly an interesting solution.
Edit: Part of the conversation was on the order of:
"Why do you want to use WiFi?"
"Normal updates, for the sake of good order."
"Don't do that. There is no need for updates."
James
James
