I just received my new inTune i3 and unlocked PCM and swapped that into my 2016 Ram 2500 w/ 6.4 Hemi. I have attempted multiple times to adjust the idle rpm along both with the 87 and MPG tunes, and while other modifications (MDS delete, tire size) seem to take effect, none of the changes I make with the idle settings do. I have verified that the firmware is up to date on the tuner.
Help?
Trouble changing idle rpm with inTune i3
Re: Trouble changing idle rpm with inTune i3
are you trying to raise it?
can you load the tune with it set where you want, then post a copy of the 'last tune written' file here from the tunes folder on the i3 drive please?
