Vehicle Not Supported after Purchasing Add License
STtxgirl
Post by STtxgirl »
Hello,
I purchased another license and updated the device from Ignition/Update agent. Before purchasing the license, it said I needed to purchase one. Now it says vehicle not supported when I plug it into the car. I've tried uninstalling. Reinstalling ect. I have a hard time calling because I work 8am-5pm CST.
What do I need to do for the tuner to recognize my vehicle? Its a 2020 Ford Explorer St. Was originally used on a F150 2.7 Ecoboost.
Re: Vehicle Not Supported after Purchasing Add License
can you post the info.xnl file from the i3 drive here so we can check it out?
STtxgirl
Post by STtxgirl »
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<tool_info platform="CHIMERA">
<registration sn="202018967" status="0" tool_oem="DIABLO" updates="0"/>
<applications count="5">
<application name="vehicle" rev="3r06c"/>
<application name="updater" rev="2r02b"/>
<application name="gui" rev="2r02q"/>
<application name="installer" rev="2r02m"/>
<application name="logger" rev="2r01u"/>
</applications>
<databases dbnames="2r01f" dtc="2r01a" vin="2r01r" SAE="3t01xe" gui="2r00n">
<database mfr="DCX" tune="2t03fs" pid="2t01vg"/>
<database mfr="FORD" tune="2t03gr" pid="2t01tc"/>
<database mfr="GM" tune="2t04gv" pid="2r01t"/>
</databases>
<system rev="1r01c" config="3r01d">
<kernel release="4.11.12-rt16-chimera8" version="#3 PREEMPT RT Wed Apr 12 15:42:11 EDT 2023"/>
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="1FM5K8GC1LGA07450" mfr="FORD" ecus="1">
<ecu calid="SRBJ1D3" spn="LB5A-14C204-ATJ"/>
</last-connected>
<licenses available="2" tuned="1">
<option mfr="DCX"/>
<option mfr="FORD"/>
<option mfr="GM"/>
<option config="CustomTuning"/>
<option config="FuelDiesel"/>
<option config="FuelGas"/>
<license vin="1FTEW1CP8GKF81085" mfr="FORD" ecus="1">
<tuned_ecu type="PCM" Tune="93 Octane Tune" calid="BNPP1"/>
</license>
</licenses>
<reg reg="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"/>
</tool_info>
I passed this over to support, but it looks like an older cal that will need to be updated by the dealer.
Update the device and it will work on your ST :)
STtxgirl
Post by STtxgirl »
I just bought another license to tune my Ford Flex 2016. It says the same thing about not being supported.
what year is the flex?
can you post the info.xml file from the i3 drive here?
Return to “i2/i3 for Ford vehicles”
