Help! T2 Won't Detect Aem Wideband 30-0300
Larry7466
Post by Larry7466 »
Hello,
I have a 2022 Ram 1500 5.7. Just did a cam swap, long tubes etc. I have an AEM 30-0300 hooked up through the eas and I can't find it in the TS or dv2. I have a base tune but need revision asap. I also can't find PID's in dv2. any help would be greatly appreciated.
Thanks!
Re: Help! T2 Won't Detect Aem Wideband 30-0300
do you see the AFR on the T2 after configuring the EAS data?
cherybomb wrote: Tue Feb 03, 2026 11:28 pm DV2 doesn’t support the AEM 30-0300 through EAS yet, so it won’t show as a PID — you’ll need to log it externally.
Slope Rider
any wideband with a 0-5V output can be logged through EAS using the analog input kit.
The AEM 30-0334 logs right through the OBDII port with T2, no EAS required.
