Fan Speed
Discuss PredatorX based support, troubleshooting or general questions.
Moderators: garrett, mikel, sohfast94
MYPTBUL
Fan Speed
Post by MYPTBUL »
I have the PreditorX on my 2019 Grand Cherokee 5.7L. I installed a 180* Thermostat, my problem is there is only one fan speed setting on the X app. It is high speed only . I don't like hearing the fan. I'm used to 3 fan speed setting. not too bad in this cold weather. Hope there will be an update for 3 speeds for the fan before the warmer months.
Re: Fan Speed
your JGC uses a desired ECT setting for the fans, and the pcm uses internal logic to run the fans as needed to achieve that temp.
Dont target a temp it cant reach, or they'll run constantly.
MYPTBUL
Re: Fan Speed
Post by MYPTBUL »
What should the temp.setting be set to?
Re: Fan Speed
We'd suggest lowering it by 20* from the factory setting.
Return to “PredatorX for Dodge/Ram vehicles”
