Someone is selling this i3, but doesn't know what model it is. Does anyone know which model it is? Here's the info from the sticker on the back of the tuner
X00011310
201628285
identifying i3 model
Re: identifying i3 model
its a platinum model that will work on GM, Dodge or Ford vehicles.
either 8145, 8245 or 8345.
Bigfatboss
I have the same issue: I bought an I3 and when I connected it. It says it was unsupported need to update firmware. Thats another problem, says unable to reslove host when I do that. Had to fight with it to join the network but finally did.
It suppose to be for a 2013 Ram. The guy I bought it from had the same vehicle. How do I verify the tuner and update it?
Its:
X00011310
202498078
Thanks for the help.
Its:
X00011310
202498078
Bigfatboss
Fixed.... Just had to be persistent in getting the I3 to finally connect to the host. Once the firmware updated loaded the unit worked.
you can always use the Update Agent software on a PC if the WiFi is not great.
