PCM
Discuss PredatorX based support, troubleshooting or general questions.
Moderators: garrett, mikel, sohfast94
Freno679
PCM
Post by Freno679 »
I just purchased the predatorx and am now waiting for the new pcm. Will I need the new pcm before I can change light settings for dtrl and fog lights? Thanks
Re: PCM
Not necessarily, no.
Freno679
Re: PCM
Post by Freno679 »
Thanks. I ask because I don’t see options for lighting control and a few others. When updating the predatorx it said I had 95 updates but the Durango will shut power off after around half an hour. So I keep losing Bluetooth connection with the unit. Can I update the unit with the vehicle running? I’m assuming I may see those options after it updates. Correct me if I’m wrong please. I’m new to all this.
Re: PCM
what year is the Durango? It wont necessarily have a ton of lighting controls like the DT Rams.
You can update the dongle anytime through the phone app. Please give our team a call if its not updating as expected.
Freno679
Re: PCM
Post by Freno679 »
It’s a 2020 Durango rt. I don’t think I’m having trouble updating it. It’s just taking awhile and the car will shut itself off after a half hour then I lose my Bluetooth connection with it so the update doesn’t finish. That’s why I was wondering if the vehicle could be running during the update. I was just hoping for the daytime running lights option because I have no way of shutting mine off through the uconnect. I believe my vehicle was originally in Canada. Thanks
Re: PCM
it should not time out if you leave the door open, have you tried that?
Freno679
Re: PCM
Post by Freno679 »
It still shuts down after awhile even with the door open. I think everything is fine. I was just hoping to have options for shutting my dtrl off and no fog light dropout.
Re: PCM
not sur eon DRL disable,we can look into fog light drop out on the durango for sure.
Freno679
Re: PCM
Post by Freno679 »
Great! That would be to have those options. Another thing I was wondering. Is it normal to lose cruise control functionality after installing the 91 octane tune, mds shut off and throttle booster turned on? Today was the first day I was in the highway and my cruise doesn’t turn on anymore. Not too worried about it. Just wondering. Thanks
Re: PCM
no tire size adjustment?
Freno679
Re: PCM
Post by Freno679 »
I have the options to make adjustments to tire size. I never used them though.
Re: PCM
Havent see cruise get disabled without adjusting tire size, not sure what would case that honestly.
Return to “PredatorX for Dodge/Ram vehicles”
