Running rich after dod afm delete
Getting p0430 and p2099 after Diablo tune. Smells very rich.
Re: Running rich after dod afm delete
the tune isnt likely causing either code.
can confirm by using the modify stock tune to disable mds, so the only change will be the MDS off. If you still have the codes, there is a mechanical or electrical issue somewhere causing the codes.
