2005 F150 issue with no idle change after tune
Re: 2005 F150 issue with no idle change after tune
still working on the issue, but here are some tunes with the idle adjusted for now.
mikewells1974
10-4.
Do I drop the tune file into the "tunes" folder?
(kinda seems obvious , but wanted to be sure lol)
Once the fix is ready , do I drop that file into the root folder?
Thank you !
Thank you !
No... you just copy it into the main/root i3 drive folder....
you do NOT copy it into any subfolder, like the Tunes folder...
mikewells1974
mikewells1974
Hey guys, any luck on a fix ?
I understand things take time , but..
let me check with the team. did the provided tunes help?
mikewells1974
Thanks , Mike.
I have not yet , but will probably try the 87 tune tomorrow. Been working on my daily driver lately , rear axle..
Thank you to all working on the issue.
mikewells1974
Hey guys.
Just touching base..
Thanks.
Thanks.
mikewells1974
Hey guys.
Been waiting on a solution for over 3 months..
Tuner was purchased first week of March.
It's difficult to consider I'm the only one having this issue, and certainly can't be the only one trying to tune a 2005 F150.
I was told there would be a solution with a simple fix/download , and certainly expected one before now.
Will there ever be a solution, and how much longer should I be expected to wait?
Very frustrated & approaching the end of my patience , which has been greater on this issue than others.
(I've had complete engines & drivelines built , installed & on the road in less time..)
Meanwhile, a very expensive little box continues to sit on my kitchen counter..
(Two of them , in fact.)
C'mon Diablo crew , I'm only asking for what was advertised function.
