2005 F150 issue with no idle change after tune
Re: 2005 F150 issue with no idle change after tune
still working on the issue, but here are some tunes with the idle adjusted for now.
mikewells1974
Post by mikewells1974 »
10-4. 👍
Do I drop the tune file into the "tunes" folder?
(kinda seems obvious , but wanted to be sure lol)
Once the fix is ready , do I drop that file into the root folder?
Thank you !
No... you just copy it into the main/root i3 drive folder....
you do NOT copy it into any subfolder, like the Tunes folder...
mikewells1974
Thank you !
mikewells1974
Hey guys, any luck on a fix ?
I understand things take time , but..
let me check with the team. did the provided tunes help?
mikewells1974
Thanks , Mike.
I have not yet , but will probably try the 87 tune tomorrow. Been working on my daily driver lately , rear axle..
Thank you to all working on the issue. 👍
