Delete Of AFM Valves After Tune Q?
Hary Gahtoe
I'm in the middle installing a full Stainless Works exhaust on 19 Camaro SS that comes without the mid AFM valves.
I have used the Diablosport I3 Platinum to program disable of AFM.
My question is;
Can I physically remove the GM exhaust AFM valve unit and plug the end of the electrical connector without getting a dash error code ?
Thanks for replies
Hary
My question is;
Thanks for replies
Hary
Re: Delete Of AFM Valves After Tune Q?
that will likely lead to a code, not housed in the pcm, making it tough to disable. Might be some simulators out there that plug in to mimic the factory valves and avoid codes.
Hary Gahtoe
So it means; I still have to connect the factory valve units to prevent error codes even though there are no actuater valves in the pipes ?
I can do that, although it does seem counter productive.
Next question then;
If this is my only option where do I look for a plug-in simulator?
I'm open to any clues or followup.
Hary
Next question then;
Hary
Hary Gahtoe
Something like this ?
exactly.
Hary Gahtoe
So the "muffler valve simulators" Will stop an error code.
Mikel reply;
"exactly"
Thank you. Much appreciated.
Hary Gahtoe
Mikel reply;
"exactly"
Hary Gahtoe
Hary Gahtoe
Have the simulator plugs installed and after a month still have error code after 3 deletes
could be a different issue. whats the code exactly?
Hary Gahtoe
The error code being something else is highly unlikely.
It's a hard code that has 6-8 hrs of post drive time and is still active
Having had negative previous experiences with HP ( very steep learning curve/ non intuitive programmimng ) I chose Diablosport I3
Error code is P26C8
P26C8 error code indicates that the Chassis Control Module has requested a Malfunction Indicator Lamp (MIL) illumination, which relates to an issue in the emissions system.
The only change has been the aftermarket exhaust and was installed with valves active and functioning
After trying an fault code (x 6 ) I bought the C8 valve delete plugs without any help
Currently I'm focusing on Corvette C7 technical info to allow car ECU's to perform "internal" bypass without 3rd party signal control
Error code is P26C8
you can try disconnecting the negative battery cable from the battery for about 30 mins... then reconnect it and drive the car, see if it triggers the CEL again...
a permanant code usually takes several drive cycles, of having no errors/issues, to clear...
Hary Gahtoe
Thank you for the replies
Does anyone know exactly "what" the ECU is measuring on valve function that would trip the code ?
The motor rotates and is heavily counter weighted by a clock spring you really can't open by hand
Logic would dictate the system is looking for a specific amount of resistance when the motor overcomes the clock spring and hits the stop mechanism
trying to apply logic to how an OEM system was engineered never works out
