Transmission Shift Settings
CT77
Post by CT77 »
Hello, I have a 2014 Sierra and have been using the Intune i3 for just about a year now. After hours of searching the internet, I've decided to see if I can get some input here. Overall I've been happy with how the tuner woke up the truck. My only issue is the 1-2 shift. My tuner is updated and I've adjusted settings for the firm shift for awhile. Today I decided to give the hard shifts a try. Not much changed. It has a lag from 1-2. Plus, I feel it shifts way too early on light acceleration. I can barely turn a corner and it shifting. Should I play around with bumping up firmness in the hard shift tune? Does raising the rpm setting help with the early shifts under light acceleration, or is that just for full throttle? Any info is appreciated. I know most will say get a custom tune, maybe someday, but for now just trying to find a happy medium. Thanks.
Re: Transmission Shift Settings
You can not adjust the part-throttle normal driving shift points with the tool itself... That can only be done via a custom tune...
The rpm shift point you see and can adjust, is only for WOT...
You will want to get a custom tune done, which I can definitely get you hooked up with...
I've done a thousand of those trucks over the years and do them weekly...
With the custom tune, you'll gain even better/quicker throttle response & acceleration, stronger/harder pull, smoother & quicker power delivery throughout the rpm's, better tranny performance/shifting, improved towing performance, etc...
I change a lot of things... a small sample of just some of the things are:  disable the DOD/AFM, disable engine torque management, adjust part-throttle fueling/timing, WOT fueling/timing, knock retard settings, throttle settings, tranny shifting settings (pressure/firmness, shift points, quickness), etc. and much more...
You can email me directly at: diablo DOT help AT gmail DOT com
-Thanks!
-Lew
CT77
Post by CT77 »
Thanks. I hope to someday get this tuned by you. I figured the rpm adjustment was for WOT. I see others have the lag when shifting from 1-2, 2-3 or both. Is that something you can also correct?
yes, as mentioned above...
