HI all,
I have a general question regarding a cluster swap...
I have a 2014 AWD RT max with 145K on the cluster odometer. I'm going to swap my 14 cluster to a 2015 charger cluster. The 2015 cluster has an odometer of 130K. When I install the 15' cluster in my car will my mileage stay put or will it change to the mileage on the 15' cluster?
Second question...if the mileage doesn't update...will I be able to update the odometer mileage with a tuner?
I have a Trinity 2 EX platinum, an XTOOL D7 scan tool, and a Tazer.
Sean
2014 CHARGER RT CLUSTER SWAP W/2015 CLUSTER
Re: 2014 CHARGER RT CLUSTER SWAP W/2015 CLUSTER
Honestly not sure here. Id check on one of the charger forums or a good FB group.
The tuner will not allow you to change it regardless.
Gotcha and thanks.
