New PCM swap option for 15-23 Chrysler/Jeep/Dodge applications
Re: New PCM swap option for 15-22 Chrysler/Jeep/Dodge applications
Want to put a order in for 2022 charger 5.7 pcm swap n tuner but idk how long pcm take lol my day driver
the swap is sent to you then you have 2 weeks to return the core, so there is plenty of time to perform the swap when you have a chance.
it must be the same type of pcm from the same vehicle range.primeauthor wrote: Tue Feb 14, 2023 8:20 pm I have my stock PCM and another used PCM from another vehicle, that I purchased to use for tuning. If I wanted to keep my stock PCM, is it permissible to send you the used PCM instead? Or is it a must that I send my stock PCM?
Re: New PCM swap option for 15-23 Chrysler/Jeep/Dodge applications
I have a 2022 Jeep Grand Cherokee Overland Pentastar 3.6L with a K&N CAI and Borla S-Type Cat-Back Exhaust. Do you offer any tuning options for this setup?
So you are saying the the Yellow sheet sent with the pcm is old info? I have an extra pcm for my 2017 ram 1500, and like the other person mentioned that he wanted to keep his original. So it is ok for me to send in the other pcm and keep my original? Thanks.mikel wrote: Wed Feb 15, 2023 11:07 amit must be the same type of pcm from the same vehicle range.primeauthor wrote: Tue Feb 14, 2023 8:20 pm I have my stock PCM and another used PCM from another vehicle, that I purchased to use for tuning. If I wanted to keep my stock PCM, is it permissible to send you the used PCM instead? Or is it a must that I send my stock PCM?
if both pcms are for the same ram, with same engine/trans combo, then its fine.
Cool, thanks for the info.mikel wrote: Thu Dec 18, 2025 10:33 am if both pcms are for the same ram, with same engine/trans combo, then its fine.
I appreciate the in-depth discussions here; it's refreshing to see diverse perspectives on fnaf 3 mechanics. Interestingly, I found that exploring fan theories adds new layers to our gaming experiences, enhancing engagement even further!
