Full cam lifter swap to delete AFM, now disable AFM in ECM
GMCSierraJ
Finishing up a full mechanical delete of a 2008 GMC Sierra 1500 5.3l. Had a collapsed lifter that trashed the cam, so it forced my hand.
Got rid of the OEM VLOM cover and went with a billet oil galley cover, so there are no connectors for the AFM VLOM solenoids. I've read that if you don't disable AFM in the ECU, it'll throw a check engine light without having the VLOM connectors plugged in. Will the Diablo sport intune i3 delete the AFM in the ECM and get rid of the check engine light in this scenario?
Thanks!
Thanks!
GMCSierraJ
Re: Full cam lifter swap to delete AFM, now disable AFM in ECM
Bump
Just need confirmation that my i3 tuner will do what I need before I plunk down the cash for another license. Here is a guy that deleted the AFM lifters and cam just like I did, then uses the Diablo Sport and it works with no trouble codes or check engine light, so I'm thinking I'd be OK. Just want confirmation.
https://youtu.be/fmhK6P13FRE?si=qd7XA4y ... te&t=1921v
Here is the full delete kit with parts where they even bundle in a diablo sport tuner. The i3 has to work, right??
https://www.amsracing.net/products/comp ... uv-engines
Thanks!
Thanks!
yes, you should be fine here.
GMCSierraJ
Wanted to post a follow-up, because these forums are handy for answers when new people stumble across them via a search/Google.
It worked, I was able to disable AFM/DOD using the i3. Runs great, no issues. The old VLOM cover with the solenoids is in the trash. Success!
awesome, enjoy!
I am thinking this answered my question. I have an i3 that I used to turn off AFM in my '19 1500 L83 LD a couple years ago. Long story short, cylinder #7 lifter failure. Well outside of warranty period and I'm in the process of disassembly. If cam is trashed I am doing the full mechanical delete.GMCSierraJ wrote: Mon May 12, 2025 4:03 pm Wanted to post a follow-up, because these forums are handy for answers when new people stumble across them via a search/Google.
So just looking for confirmation here, you were able to handle the tune side of things for the delete with just the i3 and no additional custom tune or sending the ECM out?
you will need custom tuning done for that truck, as there are trouble codes that need to be disabled for the AFM/DOD...Smokin x wrote: Thu Aug 21, 2025 9:30 amI am thinking this answered my question. I have an i3 that I used to turn off AFM in my '19 1500 L83 LD a couple years ago. Long story short, cylinder #7 lifter failure. Well outside of warranty period and I'm in the process of disassembly. If cam is trashed I am doing the full mechanical delete.GMCSierraJ wrote: Mon May 12, 2025 4:03 pm Wanted to post a follow-up, because these forums are handy for answers when new people stumble across them via a search/Google.
06MonteSS wrote: Thu Aug 21, 2025 2:15 pmyou will need custom tuning done for that truck, as there are trouble codes that need to be disabled for the AFM/DOD...Smokin x wrote: Thu Aug 21, 2025 9:30 amI am thinking this answered my question. I have an i3 that I used to turn off AFM in my '19 1500 L83 LD a couple years ago. Long story short, cylinder #7 lifter failure. Well outside of warranty period and I'm in the process of disassembly. If cam is trashed I am doing the full mechanical delete.GMCSierraJ wrote: Mon May 12, 2025 4:03 pm Wanted to post a follow-up, because these forums are handy for answers when new people stumble across them via a search/Google.
Thank you for the confirmation.
worleytrev93
I’m getting the dod kit on my 2019 suburban 6.2 right now and I was wondering why Texas speed offered a kit that came with Diablo programmer but I’m being told I will still need a custom tune what’s the point in the programmer then??
Do NOT get the inTune that they sell with their kits... The programmer that they sell with their kits is a special version tool for them that will ONLY disable the AFM/DOD settings, that's it... It can't do anything else... and it can not do custom tuning...
You will need to buy a regular full version inTune i3 8246 Platinum version tool, so that you can get a custom tune done for your truck...
the device included with those kits can 100% do custom tuning06MonteSS wrote: Sat Jun 20, 2026 11:13 am Do NOT get the inTune that they sell with their kits... The programmer that they sell with their kits is a special version tool for them that will ONLY disable the AFM/DOD settings, that's it... It can't do anything else... and it can not do custom tuning...
mikel wrote: Mon Jun 22, 2026 11:02 amthe device included with those kits can 100% do custom tuning06MonteSS wrote: Sat Jun 20, 2026 11:13 am Do NOT get the inTune that they sell with their kits... The programmer that they sell with their kits is a special version tool for them that will ONLY disable the AFM/DOD settings, that's it... It can't do anything else... and it can not do custom tuning...
You will need to buy a regular full version inTune i3 8246 Platinum version tool, so that you can get a custom tune done for your truck...![]()
I have had several people that have gotten it (their TSP-TS-3000 version programmer) and it could NOT do custom tuning... and there was even a statement on their site that it can ONLY disable the AFM/DOD setting...
https://www.texas-speed.com/brand/texas ... rogrammer/
"This tuner does not tune for performance upgrades or aggressive camshafts. Its single function is to disable DOD/AFM or MDS."
that statement is in reference to out of the box capabilities. No performance tunes, no params, just AFM disable.06MonteSS wrote: Mon Jun 22, 2026 11:24 ammikel wrote: Mon Jun 22, 2026 11:02 amthe device included with those kits can 100% do custom tuning06MonteSS wrote: Sat Jun 20, 2026 11:13 am Do NOT get the inTune that they sell with their kits... The programmer that they sell with their kits is a special version tool for them that will ONLY disable the AFM/DOD settings, that's it... It can't do anything else... and it can not do custom tuning...
If you see one that wont import a custom tune, please get me the info file.
Right... so useless for people that just get a stock non-AFM/DOD cam and want to be able to install a tune, adjust their tire size, etc...mikel wrote: Mon Jun 22, 2026 2:02 pmthat statement is in reference to out of the box capabilities. No performance tunes, no params, just AFM disable.06MonteSS wrote: Mon Jun 22, 2026 11:24 ammikel wrote: Mon Jun 22, 2026 11:02 am
the device included with those kits can 100% do custom tuning![]()
Not a big deal, as I get them hooked up with a regular full version inTune anyway...
