2009 Chrysler Aspen issues
Discuss PredatorX based support, troubleshooting or general questions.
Moderators: garrett, mikel, sohfast94
SuperSerial
Post by SuperSerial »
I'm having some trouble getting this to work on my vehicle. It says my vehicle isn't supported for some reason. The connection is also very inconsistent. Anybody have luck with it on here?
Re: 2009 Chrysler Aspen issues
it should be supported for sure. Not a ton of Aspens out there, but its not too different from a Durango as far as the PCM and calibrations go.
Can you give us a quick call at 561-908-0040 with the PredX powered up in the vehicle?
SuperSerial
mikel wrote: Thu Jul 09, 2026 11:12 am it should be supported for sure. Not a ton of Aspens out there, but its not too different from a Durango as far as the PCM and calibrations go.
I'll see if I can reach someone on Monday when you're open again.
For now, I've sent the logs through the app.
SuperSerial
I'm still getting the "Vehicle is not supported" message. I'll try and call in on Thursday to get a little more direct help.
Return to “PredatorX for Dodge/Ram vehicles”
