8/1 I updated and was trying to adjust and change my 3 Electric Fan settings. Have done this several times in the last year. I could not locate where I can change the fan settings like I used to after this update. Can you tell me, email me, where that setting would be found now ? 2007 Jeep Grand Cherokee SRT8..I3 tuner
Ed S.
i3 tuner does not show electric fan setting changes
Re: i3 tuner does not show electric fan setting changes
so did find the Fan settings...running a 180 thermostat , 2007 6.1...there are several settings..on and off...how do you and what do you set All these settings to? Off has many...On has three
lower them all by the same amount, about 20-25*
ethancole53
Thanks, that makes sense. I was wondering about the same thing with the multiple fan on/off settings. Lowering them all by the same amount seems like a safer approach than changing only one setting.sprunki I’d also be interested to know if there’s a recommended minimum temperature range to avoid the fans cycling too frequently with a 180° thermostat.
lowering them by about 20° each will put you in the right place for a 180 stat.
