GM Thermostat Variance
Discuss PredatorX based support, troubleshooting or general questions.
Moderators: garrett, mikel, sohfast94
Brett365
Post by Brett365 »
2017 Silverado HC 1500
6.2L 8L90
Is there a tuning option to tell the ECM, what temperature thermostat is installed in the cooling system?
Re: GM Thermostat Variance
No... the stock t-stat on those trucks is 207*.... and the preset tunes make changes to the fan settings based on the stock t-stat...
fan power can not be adjusted for anything lower than 192* anyway, so if you change the t-stat, I would not go any lower than a 194* t-stat... otherwise, a colder t-stat, will not allow the engine to get up to its normal operating temps... and doesn't gain you anything anyway...
Brett365
Post by Brett365 »
Thank you!
Return to “PredatorX for Dodge/Ram vehicles”
