We have a 2012 Jeep Grand Cherokee. One of the lifters went bad and we did a complete AFM bypass/overhaul. Replaced lifters and CAM shaft and used the diablosport intune i3 to turn off the AFM. Went for a test drive and the whole electrical system died. Replaced the battery and it was working again. Took the vehicle to the dealer for final check and they said PCM bad. They replaced PCM but could not turn off AFM. Our Diablosport intune i3 now says the vehicle is not supported. How do I get the intune i3 to recognize/support the new PCM the dealer installed?
Attached is the info file from our intune i3.
Intune i3 says vehicle not supported
jeepPIA2012
Re: Intune i3 says vehicle not supported
if you drove it to the dealership, the pcm was not bad
The new pcm is reporting the same calibration, and I don't see a unsupported request in the info file, so its not clear exactly why its not working currently.
I'd suggest giving our team a call with the device in the truck so we can troubleshoot, 561-908-0040
jeepPIA2012
We replaced the alternator and the battery and it would not keep any charge. Had to stop 3 time driving 15 miles from house to dealer. The clock spring needed fixed so we asked them to look at it.
We will call during work hours.
lyraellington12
It sounds like the replacement PCM may be the key here. Since the i3 worked with the original PCM and the problem started after the dealer installed the new one, I’d be curious whether the new PCM needs to be fully identified or updated by DiabloSport before the device can recognize it.slope game
If the calibration is supposed to be the same, it seems odd that the i3 would suddenly report the vehicle as unsupported. Hopefully the tech support team can pull the PCM information directly from the truck and figure out what’s different.
