New to intune i3
miketaylor2008
New to intune i3
Post by miketaylor2008 »
Hi all, i got the i3 all updated on PC, plugged it into my Jeep and chose the 93 octane tune.. It only gave me tires size and one other thing to change. I installed that successfully.. Then went in and did a modification tune where a vast list came up because I just wanted the MDS off.. I turned that off in the list and applied the tune..
Right now I am assuming that it has the 93 octane tune installed with the modificaiton of MDS OFF.. How do I see what exactly is currently installed? I guess I am not sure if BOTH are in there.
Re: New to intune i3
unless you selected a different tune the 2nd time, it applied the MDS change to whatever the last tune you loaded was, which would be the 93 tune.
Go to the settings menu and select tool info and it should show the name of the last tune written (LTW) in that list.
miketaylor2008
Thank you very much, will do that.. I appreciate you.
