2019 Ram MDS Delete with i3 NIGHTMARE!!
19RamNBSvinT
Post by 19RamNBSvinT »
Like so many others, I have purchased the AMS kit to delete MDS from my 2019 Ram with the 5.7. It’s a new body style, non e torque, vin T.
Bought the complete kit that includes the Diablo sport inTune i3 handheld tuner. Installed every single component and gasket on a new (used) engine and then installed the engine into my truck. Go to tune the truck before first start, and learn the PCM needs to be unlocked. Never mentioned anything about needing the computer unlocked prior to tuning.
Paid $250 to a local module tuning company to unlock it. Great. Truck communicates with the tuner now.
I get a message saying the tuner wouldn’t connect to some ECUs on the truck. So I go download all the latest updates using my laptop with the inTune i3 plugged in via USB. Great. Now i have all of the menus and settings/parameters available to me. I am able to hit stock tune, modify, MDS, turn Off, Write Tune.
The tune starts writing/loading. Completed. Does the key cycle game. Message opens saying write failed. So I try again. Same error messages. Try once more, fails again.
However, on the last attempt, the screen froze on the loading screen with the 4 little circles. I let it sit for about 25 minutes to see if it will unfreeze. It does not. So I unplug it and plug it back in.
Now when I plug it in and put the truck to Run but engine off, it tells me it’s in recovery mode: “This tool is in recovery mode. Tap yes to restore the original backup recommended or tap no to enter the support menu.
I tap yes. It begins writing tune. Gets to 100%. Does the key cycle thing. And then gives me another error message: “ an error occurred while restoring original backup”
Followed by an additional error message: “Tune writing failed. Unplugged the tool or press continue to reboot.”
After rebooting the tuner, I get the same error message as before stating that the tool is in recovery mode. Then it’s rinse and repeat over and over again.
If I hit no and go to the support menu on the tool, it gives me randomized key codes when I hit any of the buttons that I have no idea what they mean.
I am in desperate need of my truck and have invested a lot of $ to get to this point and still cannot start the truck.
I have been on hold with diablosport for over an hour. Can’t get anyone to ever answer the phone.
I just want my drive my truck again. I can’t get any help from diablosport so I am posting here in hopes someone will call me back or help me with this issue.
Re: 2019 Ram MDS Delete with i3 NIGHTMARE!!
Sorry to hear about this. I'm not sure how this got so off-base....
The device you got included a free pcm swap. There are documents in the box that outline the pcm swap process. There was no need to have the pcm unlocked.
Next problem is, our devices don't work with random unlocks, as we cant verify that these are done properly.
This is why its not working as expected. The PCM will need to be unlocked by us. The techs will ask you to submit our PCM cross ship form so we can send you a properly unlocked and programmed PCM that will work with our device.
https://www.diablosport.com/products/pc ... REAUTH-PCM
Once you have the pcm from us in the truck, you'll be able to tune it and disable the MDS, etc.
