Has anyone attempted to mount the predator somewhere on your dash that would not involve drilling or sticky tape? There is a good reason for my question but I cannot reveal it at this time... it's a surprise
Predator Dash Attachment
- fordomatic69
Hey All,
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
RE: Predator Dash Attachment
Obviously its for logging purposes.
Hmmm, maybe for the bling factor?? "Hey, look at what I got beeeotch!!!"
I didn't drill or use sticky tape (actually tried the sticky tape but it didn't hold -- even the permanent type). I used the mounting putty. Does that count?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
industrial grade/strength velcro works wonders.... a strip on the dash, the other piece on the back of the predator, and just attach and remove at will... holds great...
course, I guess ya could always zip-tie it to a vent too
- fordomatic69
I was thinking about some sort of a vent mount but I don't think they make anything big enough to hold the size or weight of the predator.
Fordomatic Says:
larryc7777
Since there are PID display/datalogger units available(such as the MSD Dashhawk), I'm wondering why you would want to hang a huge item like the Predator from your dash? But that's totally your business.
You might look into those universal cellphone/PDA mounts that squeeze from both sides. The foam rubber padded "jaws" supply good clamping force & the "shoulder" area of the Predator will help support the weight. You'll probably have to screw mount the holder though.
http://www.arkon.com/pdamount.php
- fordomatic69
I was thinking of "Showing off" the predator at various events in and around the area. I was going to use the predator + my new in dash carputer to show the nice guages in the data viewer. as well as mont the predator so it is not just sitting on the seat... I wanted things to look clean.
- carp1.JPG (97.9 KiB) Viewed 2571 times
- carp2.JPG (109.07 KiB) Viewed 2571 times
Fordomatic Says:
