Dibalo Performance Tune and 91 Octane Question
mr_boogeyman
Ok so i installed the performance tune that came with my diablo U7146 . When I read the instructions it said since I'm in California and we only have 91 octane and not 93 octane to do a 10% retard so I did. Reading in these forums i says to only do 2% retard for 91 octant so did I do it right or is the instruction booklet wrong?
Also my car was 80% filled with 87 octane gas when I did the tune so i have to wait till I use up the gas before i can fill it up with 91, will this hurt the engine?
RE: Dibalo Performance Tune and 91 Octane Question
You are confusing the 10% retard for the U7146 with the 2* of global spark retard for 05+ Mustangs....
mr_boogeyman
Ok so what I did is change the following 2 settings to "10"
Spark Advance 2k-4k
Spark Advance 4k-7k
So is that right for my 91 octane gas?
Spark Advance 2k-4k
Spark Advance 4k-7k
mr_boogeyman
Forgot to mention i drive an 2001 Mustang GT automatic
It should be set to -10
mr_boogeyman
You are running a 91 tune right? You shuld only have to add the 91 tune and not change anything else to you car right? And i wouldn't be running a 91 tune when you are still burning 87 octane gas, wait till your tank is as low as you can go, add 91. Then drive it a couple miles to get the 87 out of the fuel lines, and that will be good.
mr_boogeyman
mr_boogeyman,
run the predator's 87 tune until the gas is out, then run the 91 gas, when you install the 93 octane tune go into modify tune in menu!
go to Global Spark Advance, when the scene comes up, it should resemble a slide scale(-10---------X--0---------10+) move cursor two degrees to the left as I shown in example scale! That retard all timing in program to 91 octane setting! upload tune follow instructions and drive the hell out of the car! Good luck avoiding tickets after that! LOL
2006 Roush Stage 1 F150
4x4 Supercab
Mildly Modified By Troyer Performance &
DiabloSport Tuning
www.Troyerperformance.com
www.Roushperf.com
4x4 Supercab
DiabloSport Tuning
www.Roushperf.com
mr_boogeyman
THANK YOU......I had at -10 before like Mike said and also since it said to go to 10% retard on the manual, hopefully it didn't mess anything upamsounds wrote:mr_boogeyman,
40thmustang
Mustangs do not get 87 octane tunes...amsounds wrote:mr_boogeyman,
wayniac_00
